Two-way synchronization with delete with SFTP/FTP server
WinSCP synchronization functionality is state-less. So when there is a file on one side, which is absent on the opposite side, WinSCP is not able to determine, if the file was added on the first side, or removed on the latter. For this reason in the Both direction, WinSCP does not support the Delete files option.
This extension uses a cache file to remember the list of local files after the previous synchronization. It uses the cached list to determine, if the file was added or removed.
You can install this script as a WinSCP extension by using this page URL in the Add Extension command.
powershell.exe -File C:\path\SynchronizeTwoWayDelete.ps1 -sessionUrl "sftp://user:password;fingerprint=ssh-rsa-xxxxxxxxxxx...@example.com/" -localPath "C:\local" -remotePath "/remote" -listPath "C:\cache\example.txt"
# @name         Two-Way Synchronization with Delete...
#                   -sessionUrl "!E" -localPath "%LocalPath%" -remotePath "%RemotePath%" ^
#                   -listPath "%ListPath%" -refresh -pause -sessionLogPath "%SessionLogPath%"
# @description  Synchronizes files on local and remote directories including file deletions ^
#                   by remembering a list of previous local files
# @version      2
# @homepage     https://cdn-teaseib9pohshoma.winscp.net/eng/docs/library_example_two_way_synchronize_delete
# @require      WinSCP 5.18.1
# @option       - -run group "Directories"
# @option         LocalPath -run textbox "&Local directory:" "!\"
# @option         RemotePath -run textbox "&Remote directory:" "!/"
# @option       - -run group "Options"
# @option         ListPath -run textbox "Re&member previous local files in:" ^
#                     "%LOCALAPPDATA%\WinSCP\TwoWayDelete\!N.txt"
# @optionspage  https://cdn-teaseib9pohshoma.winscp.net/eng/docs/library_example_two_way_synchronize_delete#options
param (
    $sessionUrl = "sftp://user:mypassword;fingerprint=ssh-rsa-xxxxxxxxxxx...@example.com/",
    $localPath,
    $remotePath,
    $listPath,
    $sessionLogPath = $Null,
    [Switch]
    $pause,
    [Switch]
    $refresh
try
    # Load WinSCP .NET assembly
    # Setup session options from URL
    $listPath = [Environment]::ExpandEnvironmentVariables($listPath)
    $listDir = (Split-Path -Parent $listPath)
    New-Item -ItemType directory -Path $listDir -Force | Out-Null
    if (Test-Path $listPath)
        Write-Host "Loading list of previous local files..."
        [string[]]$previousFiles = Get-Content $listPath
    else
        Write-Host "No list of previous local files"
        $previousFiles = @()
    $needRefresh = $False
    try
        Write-Host "Connecting..."
        Write-Host "Comparing files..."
        $differences =
            $session.CompareDirectories(
                [WinSCP.SynchronizationMode]::Both, $localPath, $remotePath, $False)
        if ($differences.Count -eq 0)
            Write-Host "No changes found."
        else
            Write-Host "Synchronizing $($differences.Count) change(s)..."
            foreach ($difference in $differences)
                $action = $difference.Action
                if ($action -eq [WinSCP.SynchronizationAction]::UploadNew)
                    if ($previousFiles -contains $difference.Local.FileName)
                        $difference.Reverse()
                    else
                        $needRefresh = $True
                elseif ($action -eq [WinSCP.SynchronizationAction]::DownloadNew)
                    $localFilePath =
                        [WinSCP.RemotePath]::TranslateRemotePathToLocal(
                            $difference.Remote.FileName, $remotePath, $localPath)
                    if ($previousFiles -contains $localFilePath)
                    else
                        # noop
                elseif ($action -eq [WinSCP.SynchronizationAction]::DownloadUpdate)
                    # noop
                elseif ($action -eq [WinSCP.SynchronizationAction]::UploadUpdate)
                else
                    throw "Unexpected difference $action"
                Write-Host -NoNewline "$difference ..."
                try
                    $difference.Resolve($session) | Out-Null
                    Write-Host -NoNewline " Done."
                finally
                    Write-Host
    finally
        # Disconnect, clean up
        $session.Dispose()
    # Refresh the remote directory in WinSCP GUI, if it was changed and -refresh switch was used
    if ($refresh -and $needRefresh)
        Write-Host "Reloading remote directory..."
        & "$env:WINSCP_PATH\WinSCP.exe" "$sessionUrl" /refresh "$remotePath"
    Write-Host "Saving current local file list..."
    $localFiles =
        Get-ChildItem -Recurse -Path $localPath |
        Select-Object -ExpandProperty FullName
    Set-Content $listPath $localFiles
    Write-Host "Done."
    $result = 0
catch
    $result = 1
if ($pause)
exit $result
Options
Directories
Enter root directories for the synchronization into the two directory boxes. By default the current working directories will be used. The directories can be specified, when executing the extension only.
Options
In the Remember previous local files in box, specify the path to a list text file that will be used to remember the files that existed after the synchronization. The file (and its parent folders) are automatically created, if it does not exist yet. By default, the file is stored in %LOCALAPPDATA%\WinSCP\TwoWayDelete and named after the current session. This options are available, when executing the extension only.
Preferences
These options are available on the Preferences dialog only.
In the Session log file, you can specify a path to a session log file.
In the Keyboard shortcut, you can specify a keyboard shortcut for the extension.
