Problem with a Vb app and runing the Winscp script
Hi
I get the following error when I try to upload a file:
Error: Cannot create remote file '/MySftp.com/files/path/Test/uplaod.txt'.
Permission denied.
Error code: 3
Error message from server: Can not create /MySftp.com/files/path/Test/uplaod.txt
Can someone tell me what this truly means and what I can do about it.
Here is the code that I have in the VB.Net application:
Permission denied.
Error code: 3
Dim Filename As String = "C:\Users\ed.walsh\Desktop\ftp\*.txt"
Dim uploadFolder As String = "/us1.hostedftp.com/files/path/Testing/*"
With sessionOptions
.Protocol = Protocol.Sftp
.HostName = "MySftp.com"
.UserName = "My User name"
.Password = "My pass"
.SshHostKeyFingerprint = "ssh-dss bbbb xxxxxxxxxxxxxxxxxxxxxxxxxxx="
.AddRawSettings("FSProtocol", "2")
.PortNumber = 22
End With
Using session As New WinSCP.Session
session.Open(sessionOptions)
Dim transferOptions As New WinSCP.TransferOptions
transferOptions.TransferMode = WinSCP.TransferMode.Binary
Dim transferResult As WinSCP.TransferOperationResult
transferResult = session.PutFiles(Filename, uploadFolder, False, transferOptions)
transferResult.Check() 'THrows the first error if not successful
For Each transfer As WinSCP.TransferEventArgs In transferResult.Transfers
'Write results to Event Viewer or SQL table or Log Table
'This will display a message box with the results
MessageBox.Show(“Upload of file “ & transfer.FileName & ” successful.”)
Next
End Using
