FileMask
octavianD
FileMask
I was wondering if there is a way of making the filemask to process a logical AND on file inclusions rather then OR.
I would like to download files that are older than 20minutes only with a specific filename.
In this case the filemask would look like this:
"<20N; somefile.txt | */ " however this would actually download somefile.txt even if the file is newer than 20minutes.
Can one have this instead " <20N && somefile.txt" It doesn't seem to work using the editor as this one only accepts one parameter per line.
Kind regards,
Octavian
