Error with Windows Scheduler
grantt
Hi Martin,
I've set up a script to sftp synchronize. It works beautifully when I manually run the command "C:\Program Files (x86)\WinSCP\winscp.exe" /script=C:\winSCP_Synch\synchroniseToJumpHost.txt. When the task is scheduled to run the same command, the SFTP session appears to fail, throwing a number of errors that indicate that the process cannot see the local directory. Hopefully the log file attached can help shed some light on the error.
Grant
  • log.txt (8.81 KB, Private file)
