how to delete fives older than x amount of days
The below Powershell script connects to my SFTP sever and deletes all my files under the path /test/my_file/.
Is there a way where I can say only delete files that is five days old under the path /test/my_file/
Add-Type -Path " WinSCPnet.dll"
HostName = "example.test.com"
UserName = "username"
Password = "password"
SshHostKeyFingerprint = "ssh-rsa 1234 xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx:xx"
$sessionOptions.AddRawSettings("ProxyMethod", "0")
$sessionOptions.AddRawSettings("ProxyHost", "123.45.67.8")
$sessionOptions.AddRawSettings("ProxyPort", "8080")
try
# Remove files
$session.RemoveFiles("/test/my_file/*").Check()
finally
$session.Dispose()
thank you in advance.
try
# Remove files
finally
$session.Dispose()
