deleting local files older than 7 hours
eibyer
United States
I thought I had a grasp of the basic syntax but I guess not. For starters, I tried to list files older than 7 hours in the console but not having any luck.
What would be the command syntax to delete local files older than 7 hours?
My target is to download a specific file from a remote site every hour, rename it by appending the HH and MM to the filename. Delete any local files older than 7 hours so I don't end up with too many.
Thanks for any assist.
