webdav share upload
Andre1
webdav share upload
Hi, I'm stuck with the following problem.
Overview:
Files are created in the folder (Local) and should be transferred to wedav(remote). I could solve this with a batch/Winscp.
New requirement:
The files in the Local folder must be checked and files with the name XXXX_YYYY_XXX
to remote(webdav) ABC
And files named XXXX_ZZZZ_XXX should be transferred to remote(webdav) XYZ
Unfortunately, I have only been working with WinSCP for a short time and I am not sure if it can be solved this way.
The best thing would be if I could run this in a batch as a Windows task
I hope you can help me
Andre1
hello
I could solve the problem with the following parameter.
"put -delete -filemask="*XYZ*.pdf" \\ABC\DEF\GHI" ^
The entry can be closed/deleted
