WINSCP can't find host on command line
I have an unusual problem.
I have a batch file that is executed as follows:
When I run the batch file from either Windows or the Command Prompt, it executes perfectly.
However, when I run the batch file from a SQL Server job using the command processor utility, I get the following in the (debug level 2) log:
The script looks like this:
    I acknowledge that this might be a permissions issue, but to solve that problem, I need to know where, exactly, are these sites stored?  Why can't WINSCP find it's own data?
C:\Progra~2\WinSCP\WinSCP.com /script=d:\apps_to_compile\cff\winscp.txt
D:\apps_to_compile\cff>C:\Progra~2\WinSCP\WinSCP.com /script=d:\apps_to_compile\cff\winscp.txt
Searching for host...
Host "CCS_DEV_SERVER" does not exist.
(null)
open CCS_DEV_SERVER call site lrecl=900 blksize=27900 recfm=fb cy pri=10 put -transfer=binary D:\out.fil '"CCS.G.IN(+1)"' exit
