Help with Command Line
jvenables
Hi All,
New User,
I am trying to run a DOS command to connect to a server, navigate down 2 folder levels, copy a file and put it on a folder on my server and then delete the file from the server
Below is command that i am trying, i am having an issue with the deletion of the file part after I copied it. Would anyone be able to give me some pointers, if i remove the -delete part the command does what i want apart from the deletion part
winscp SERVER /command get -delete /FOLDER1/FOLDER2/*.zip d:\FOLDER3\FOLDER4
