Synchronization Failure
                Hi everyone. I am trying to get one of the scripts found on this site to work for me. I am using the download and delete script but every time i plug in my variables and run in powershell i get an error of the value supplied is not valid. Any ideas?
        param ( $localPath = "C:\temp\Target2", $remotePath = "/out" ) try { # Load WinSCP .NET assembly Add-Type -Path "WinSCPnet.dll" # Setup session options $sessionOptions = New-Object WinSCP.SessionOptions -Property @{ Protocol = [WinSCP.Protocol]::Sftp HostName = "spscommerce.com" UserName = "santa" Password = "christmas1234" SshHostKeyFingerprint = "xxxxxxxxxxxxxxxxxxxxxxxx" } $session = New-Object WinSCP.Session try { # Connect $session.Open($sessionOptions) # Synchronize files to local directory, collect results $synchronizationResult = $session.SynchronizeDirectories( [WinSCP.SynchronizationMode]::Local, $localPath, $remotePath, $False) # Deliberately not calling $synchronizationResult.Check # as that would abort our script on any error. # We will find any error in the loop below # (note that $synchronizationResult.Downloads is the only operation # collection of SynchronizationResult that can contain any items, # as we are not removing nor uploading anything) # Iterate over every download foreach ($download in $synchronizationResult.Downloads) { # Success or error? if ($download.Error -eq $Null) { Write-Host "Download of $($download.FileName) succeeded, removing from source" # Download succeeded, remove file from source $filename = [WinSCP.RemotePath]::EscapeFileMask($download.FileName) $removalResult = $session.RemoveFiles($filename) if ($removalResult.IsSuccess) { Write-Host "Removing of file $($download.FileName) succeeded" } else { Write-Host "Removing of file $($download.FileName) failed" } } else { Write-Host ( "Download of $($download.FileName) failed: $($download.Error.Message)") } } } finally { # Disconnect, clean up $session.Dispose() } exit 0 } catch { Write-Host "Error: $($_.Exception.Message)" exit 1 }
