Scripting Assistance
What am I missing??? Say's object required and its not uploading.
Getting error:
Error opening SFTP session: Object required
Getting error:
With objSFTPSessionOptions .PortNumber = 2224 .Protocol = 0 .HostName = SFTP_HOST_NAME .UserName = strSFTPUsername .Password = "password" .SshPrivateKeyPath = SFTP_AUTHENTICATION_KEY '.PrivateKeyPassphrase = SFTP_KEY_PASSPHRASE .SshHostKeyFingerprint = SSH_HOST_KEY End With On Error Resume Next Set objSFTPSession = WScript.CreateObject("WinSCP.Session") ' Connect objSFTPSession.Open objSFTPSessionOptions If Err.Number <> 0 Then AmendLog "Error opening SFTP session: " & Err.Description processFile = False Exit Function End If ' Upload files Set objSFTPTransferOptions = WScript.CreateObject("WinSCP.TransferOptions") objSFTPTransferOptions.TransferMode = TransferMode_Binary Set objSFTPTransferResults = objSFTPSession.PutFiles(strDestinationPath, SFTP_SUBFOLDER, False, objSFTPTransferOptions) ' Throw on any error objSFTPTransferResults.Check ' Print results For Each objSFTPTransferResult In objSFTPtransferResults.Transfers If objSFTPTransferResult.Error = Null Then AmendLog "Upload of " & objSFTPTransferResult.FileName & " succeeded" bolTransferSuccess = True 'Move file to processed folder AmendLog "Moving processed file to Submitted folder" objFSO.MoveFile strDestinationPath, PROCESSED_FILE_DIRECTORY & "\" & strDestinationFileName Else AmendLog "Upload of " & objSFTPTransferResult.FileName & " failed with error " & objSFTPTransferResult.Error.Message bolTransferSuccess = False End If Next ' Disconnect, clean up objSFTPSession.Dispose 'Clean up Set objRecord = Nothing Set objConn = Nothing Set objSourceFile = Nothing Set objFSO = Nothing 'Check for presence of failed transfer of one or more files If bolTransferSuccess = True Then processFile = True Else processFile = False End If End Function
