Problem with download files from host to local directory
PEROPT
Problem with download files from host to local directory.
There is no problem getting to a remote address, but when I want to download a file from there I get this message.(Copying files from remote side failed.
%RMS-F-SYN, file specification syntax error).
I use a proxy connection to access the official pages.
Hello
Peter
PEROPT
I can't find the session log file. I'm attaching a printscreen folder with the program (see printscreen 2).I can't use SFTP instead of FTP, if I want to connect via SFTP it shows me the following (see printscreen 3).
I access the official pages of the public administration via my home computer.
I also use the WS FTP95 program, where I have the same settings and have no problems transferring files from work sites.
WMS or VMS? WinSCP has a limited compatibility with the VMS FTP server in the default configuration.
Did you follow the FAQ above? Cannot you use SFTP?
