Problem with space in local patl
Good morning,
Could you help me please about a script to simply copy files from local folder to remote folder. My script is the following :
The connection is working fine but the command put doesn't work :-(
I have this issue : '"put "' is not recognized as an internal or external command,
operable program or batch file.
Could you help me please ?
I read this page https://winscp.net/eng/docs/scripting#quotes but I don't understand where is the error.
Thanks a lot !
set localpath = D:\test test\test\*.* set remotepath = C\remotetest remote test\test winscp.com /command "open ftps://userlogin:password@remoteftp/" "put %localpath% %remotepath%" "exit"
Thanks a lot !
