Need help for downloading a list of files
mobiz-at
Vienna
Hi there!
I would need some help to create a script to download a bunch of selected files from a designated folder. All files are in the same folder on the ftp-server. The folder holds appr. 80.000 files and I would need to download 1200 of them as set out in a list (e.g. images.txt or images.csv as attached).
I know that it works via get command but don't know which command(s) are needed to call the items in the list.
Description: list of files to download
