Issues with synchronize script
we want to synchronize Windows CA CRL directory to remote website.
If I use:
It will throw an error:
If I change the local folder to
Is there something in the code blocking access to
If I use:
synchronize remote -delete -filemask="*.crl; *.crt; *.pem" "C:\Windows\System32\certsrv\CertEnroll" "/remote/path/CertEnroll"
This happens even when running from an administratorError listing directory 'C:\Windows\System32\certsrv\CertEnroll\*.*'.
Error retrieving file list for "C:\Windows\System32\certsrv\CertEnroll\*.*".
System Error. Code: 3.
The system cannot find the path specified
(A)bort, (R)etry, (S)kip: Abort
cmd.exe in which we can cd to the directory and list its contents (and read them) just fine.
C:\Test all is well, but the file aren't there.
C:\Windows or something?
