File sending stops after SSH_FXP_SETSTAT
I'm noticing that sometimes (that does not happen always) the log shows strange entries:
as you can see the copy process has been initiated (files are obfuscated) from the local disk to the remote directory. The last entry in the log is from
the next is
so more than 5 minutes later. It simply aborted. Any idea what could cause such strange behaviour?
> 2021-10-21 15:12:43.376 Script: put -nopermissions -preservetime -transfer="binary" -filemask="*.*" -- "\\UNC_PATH\*.*" "/*.*"
. 2021-10-21 15:12:43.376 Copying 1 files/directories to remote directory "/"
. 2021-10-21 15:12:43.376 PrTime: Yes; PrRO: No; Rght: rw-r--r--; PrR: No (No); FnCs: N; RIC: 0100; Resume: S (102400); CalcS: No; Mask: *.*
. 2021-10-21 15:12:43.376 TM: B; ClAr: No; RemEOF: No; RemBOM: No; CPS: 0; NewerOnly: No; InclM: *.*; ResumeL: 0
. 2021-10-21 15:12:43.391 AscM: *.*html; *.htm; *.txt; *.php; *.php3; *.cgi; *.c; *.cpp; *.h; *.pas; *.bas; *.tex; *.pl; *.js; .htaccess; *.xtml; *.css; *.cfg; *.ini; *.sh; *.xml
. 2021-10-21 15:12:43.391 File: 'xyz.csv' [2021-10-21T13:04:10.964Z] [85292]
. 2021-10-21 15:12:43.391 Copying "xyz.csv" to remote directory started.
. 2021-10-21 15:12:43.391 Binary transfer mode selected.
. 2021-10-21 15:12:43.391 Opening remote file.
> 2021-10-21 15:12:43.391 Type: SSH_FXP_OPEN, Size: 63, Number: 259
< 2021-10-21 15:12:43.454 Type: SSH_FXP_HANDLE, Size: 45, Number: 259
> 2021-10-21 15:12:43.454 Type: SSH_FXP_WRITE, Size: 32825, Number: 774
. 2021-10-21 15:12:43.469 2 skipped SSH_FXP_WRITE, SSH_FXP_READ, SSH_FXP_DATA and SSH_FXP_STATUS packets.
> 2021-10-21 15:12:43.469 Type: SSH_FXP_CLOSE, Size: 45, Number: 1540
> 2021-10-21 15:12:43.469 Type: SSH_FXP_SETSTAT, Size: 59, Number: 521
. 2021-10-21 15:18:05.241 --------------------------------------------------------------------------
. 2021-10-21 15:18:05.241 WinSCP Version 5.9.6 (Build 7601) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Enterprise)
. 2021-10-21 15:18:05.241 Configuration: nul
. 2021-10-21 15:18:05.241 Log level: Normal> 2021-10-21 15:12:43.469 Type: SSH_FXP_SETSTAT, Size: 59, Number: 521
. 2021-10-21 15:18:05.241 -------------------------------------------------------------------------- . 2021-10-21 15:18:05.241 WinSCP Version 5.9.6 (Build 7601) (OS 6.1.7601 Service Pack 1 - Windows Server 2008 R2 Enterprise)
