Overwrite file question
mgrosso
USA
Hi - I am using a script to PUT a file onto a server which does not allow me to overwrite files but does allow me to PUT new files, delete files, and re-name files. My goal is to replace one or more files that may already exist in the target folder.
After researching the forums for a while it seems one way to implement this is to use RESUMESUPPORT as this will transfer my file to a new file name, delete the existing file, and rename the transferred file from its temporary name to a permanent name.
This mostly works as expected but once I try to transfer the file for the 2nd time I get this message:
> 2022-01-25 15:44:38.138 Type: SSH_FXP_LSTAT, Size: 37, Number: 519
< 2022-01-25 15:44:38.170 Type: SSH_FXP_ATTRS, Size: 37, Number: 519
. 2022-01-25 15:44:38.170 File exists: Test.csv;-;25;2022-01-25T21:43:04.000Z;3;"" [0];"" [0];rwxrwxrwx;1
. 2022-01-25 15:44:38.170 Existing file looks like a symbolic link, not doing resumable transfer.
Using scripting (via cmd.exe) is there any way to avoid this and force WinSCP to perform a transfer with resume support despite the symlink?
Thanks!
