Getting exit code 255 when executing Process task in SSIS using WinSCP
I'm running and SSIS package in VS 2017 and have the latest version of WinSCP installed.
Before the server was updated I hadn't had any problems with running the same SSIS package.
Now when I try to execute Batch file in SSIS it comes back with the error
I can run the batch file outside of WinSCP fine and it runs without issue, only when trying to run it from VS. Any help would be appreciated TIA[Execute Process Task] Error: In Executing "C:\Program Files (x86)\WinSCP\NutriKids_sftp.bat" "" at "C:\Program Files (x86)\WinSCP", The process exit code was "255" while the expected was "0".
