Any version of WinSCP freezes
I have always used the current version of WinSCP without any problem. For some reason, WinSCP (commander interface) will not open starting today. Anytime I open it, it just sits in the task manager using around 38.1 MB of memory (Windows 10). No GUI interface will actually appear. I have uninstalled/reinstalled and also tried installing several older versions but not having any luck. I even tried the newest beta version with no luck.
I am not sure if any of these Windows error logs will help but I'm including them just in case.
Thanks for any help you're able to provide!
The program WinSCP.exe version 5.19.6.12002 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 41c0
Start Time: 01d843843d4bb4b6
Termination Time: 4294967295
Application Path: C:\Program Files (x86)\WinSCP\WinSCP.exe
Report Id: a9e2e898-7e99-4379-9435-a2cdbc3bd148
Faulting package full name:
Faulting package-relative application ID:
Hang type: Top level window is idle
Fault bucket 1228464977697404181, type 5
Event Name: AppHangB1
Response: Not available
Cab Id: 0
Problem signature:
P1: WinSCP.exe
P2: 5.19.6.12002
P3: 00000000
P4: ea7d
P5: 67247104
P6:
P7:
P8:
P9:
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA5A9.tmp.WERInternalMetadata.xml
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Critical_WinSCP.exe_2babc442f64ddf9626381ade5a6d267ef624deb_4b332615_a2dcdd1f-c0af-45bc-b2aa-fe22e10690f9
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: ed137b06c81829ce110c626376a97515
Cab Guid: 0
