FTP Server - Access Denied
SkiierSquared
StrangeAeons
I'm trying to make a FTP server to share files with friends. I seem to have done everything correctly, but I continue to have an 'Access Denial' error/issue.
Could anyone help me try and troubleshoot this? Not sure where to turn to...
Skiier.
SkiierSquared
Re: FTP Server - Access Denied
I'm a bit confused, this is the WinSCP forums is it not? I am trying to create an FTP server for file sharing with the WinSCP program? Where else can or should I turn to with these questions...?
The error comes from the server. It's most likely not WinSCP's fault that the server denies you the access. Unless it works with any other FTP client. Does it?
I've suggested, where you can ask your question, in my previous post.
That's not what I was asking. I was asking, if other software FTP clients (not WinSCP) work in the same setup (same local machine, same FTP account), in which WinSCP does not.
