Using Session to Start a Background Process using Ampersand &
gsc52
USA
This may have already been discussed. But does WinSCP still not support starting processes in the background on Linux server through SSH. Runs all other commands fine.
Code Snippet
using (var session = new WinSCP.Session())
    // Connect
    session.Open(sessionOptions);
    string cmd =  "./go.sh &";
    var res = session.ExecuteCommand(cmd);
    if (!res.IsSuccess)
        throw new Exception($"Unable to Execute Start Command {cmd} ERROR:{res.ErrorOutput}");
Is there a possible workaround for this?
-bash: line 9: syntax error near unexpected token `;'
-bash: line 9: `./go.sh & ; echo "WinSCP: this is end-of-file:$?"'
