WinSCP password includes alias character
zzahierarba
I have a question, refer to the code snippet below which runs on python,
process = subprocess.Popen(
    [r'path\WinSCP.com', '/ini=nul', '/command',
     'open ftp://user:password@host', 'get something.txt', 'exit'],
    stdout=subprocess.PIPE, stderr=subprocess.PIPE)
for line in iter(process.stdout.readline, b''):
    print(line.decode().rstrip())
Can I know if it will work if the password has alias character inside? for example: banana@72
Let's say if it doesn't work, how should I approach for this kind of password?
I tried to include the password as mentioned but seems like it failed to connect and proceed to timeout.
Hope to get some help here.
