WinSCP not accepting PowerShell variable
lmccourt
Been trying to use winscp in PowerShell, it works with the source file directly in the PutFiles function. But when I switch to a variable in PutFiles it says it succeeds, but not files end up on the server.
This is what I am using to start
try
    # Load WinSCP .NET assembly
    Add-Type -Path "D:\Cognos_control_m_scripts\GINZ\scripts\WinSCPnet.dll"
    # Setup session options
        HostName = "xxxx"
        UserName = "xxxx"
        Password = "xxxx"
        SshHostKeyFingerprint = "xxxx"
    $session.DebugLogLevel = 2
    $session.DebugLogPath = "D:\WinSCPDebugNewTest.xml"
    try
        # Connect
        # Upload files
        $transferOptions.TransferMode = [WinSCP.TransferMode]::Binary
        $ftp_file = "D:\testlog.txt"
        $transferResult =
            $session.PutFiles($ftp_file, "/ftpserver/inbox/zzzzfilexzz.zip", $False, $transferOptions)
        # Throw on any error
        $transferResult.Check()
        # Print results
        foreach ($transfer in $transferResult.Transfers)
            Write-Host "Upload of $($transfer.FileName) succeeded"
    finally
        # Disconnect, clean up
        $session.Dispose()
    exit 0
catch
    exit 1
Anyone seen this type of behaviour before?
