Skipping Files
HI everyone,
Hopefully someone can help guide me on this.
We have a script we run as a scheduled task every 15 mins which copies files to a SFTP location, then after this a
For some reason it keeps skipping a few files each day which are not uploaded, but do seem to be moved via the
We upload every 15 mins, and each batch would have a max of 20 files
The part of the script used to copy the files to the SFTP location after logging in, and then move so we have our local copy is as below:
Can anyone suggest why it may skip the occasional file in the
Many thanks in advance.
move command to keep a copy of the files locally.
move part later in the script.
"put *.xml -nopreservetime -nopermissions" ^ "exit" move D:\xxxxx\*.xml D:\yyyy\
put part but the file is successful moved to the backup location,
