WinSCP 5.19.2 (Build 11614), OpenSSH 8.7 standard configuration supported?
                Hi all
We are using a BizTalk Server 2016 to connect to an SFTP server for uploading messages.
Technically BizTalk is using WinSCP as "engine" for that, and it's locked to a specific version of WinSCP.
The company we are sending files to have informed us that they have tightened their security and will only allow connection to their SFTP server if you can handle algorithms as per the OpenSSH 8.7 standard configuration.
Is that supported in/with WinSCP 5.19.2 (Build 11614)?
Kind Regards
Mads K. Clausen.
Kind Regards
Mads K. Clausen.
