Special symbols in folder/filenames
Good day.
I don’t understand what to do if there are special characters in the file names.
A simple script for downloading files from the server:
Works great, but file
A simple script to upload a file to the server:
Let's look at the log:
Two problems:
The first is that we cannot load the
The second problem is that the error interrupts the execution of the script and the next
_%3A_.log arrives renamed to _%253A_.log. Which is not very good.
Copying "_%3A_.log" to remote directory started.
Status code: 10, Message: 771, Server: The file path does not exist or is invalid., Language: en
(ETerminal) File path does not exist or is incorrect
Can't create a file on the server '/dl/_:_.log'. ("The file path does not exist or is incorrect
Error code: 10The first is that we cannot load the
_%3A_.log file
test.log file is not copied.
