Behaviour of mkdir if folder already exists?
Hi all,
I am using this Script:
It works fine when the
Here is the excerpt from the log:
Hope it's any easy fix.
Regards,
Leigh
open ftp://mincad:redacted.redacted.redacted.redacted -explicitssl -passive=on mkdir "/root/folder" cd "/root/folder" put "c:\localfolder\file.exe" "file.exe" exit
/root/folder does not exist, but if it does exist, I get a fatal error:
> 2024-06-03 17:11:04.951 Script: mkdir "/root/folder" . 2024-06-03 17:11:04.951 Creating directory "/root/folder". > 2024-06-03 17:11:04.951 CWD /root < 2024-06-03 17:11:04.966 250 CWD command successful > 2024-06-03 17:11:04.966 MKD folder < 2024-06-03 17:11:04.982 550 folder: File exists . 2024-06-03 17:11:04.982 Asking user: . 2024-06-03 17:11:04.982 Error creating folder '/root/folder'. ("folder: File exists") < 2024-06-03 17:11:04.982 Script: Error creating folder '/root/folder'. < 2024-06-03 17:11:04.982 Script: folder: File exists . 2024-06-03 17:11:04.982 Answer: Abort . 2024-06-03 17:11:04.982 Script: Failed . 2024-06-03 17:11:04.982 Script: Exit code: 1 . 2024-06-03 17:11:04.982 Disconnected from server
Regards,
Leigh
