Generate HTTP URL Extension doesn't work on Windows 11 24H2
I ran into an issue today where using the Generate HTTP URL extension returns an error - Command failed with return code -1073740940.
After updating to the latest version (and then to the latest beta) of WinSCP didn't resolve the issue, I was curious if the recent Windows 11 feature update (24H2) had something to do with it.
I tested the same server configuration with the latest version of WinSCP installed on an old laptop with Windows 11 23H2 installed, and I can confirm that it works on that one.
I'd appreciate it if you could check what changed in Windows that affects using the extension.
Thanks!
Thanks!
