External applications optional client path options
For some sessions, I need to pass a private key file via command line to the external application (
Thanks.
... -k !K). If the session does not have a private key configured, the application starts with the -k option alone. That application fails to start because the expected key file is not present on the command line. Is there a way to configure the terminal client path depending on whether the session has a key or not?
Thanks.
