Can't connect to Isilon storage with S3 protocol
lebeg
I have a problem connecting to an Isilon storage with the S3 protocol, I get the following error:
Could not read status line: connection was closed by server
WinSCP: 6.3.6 (Build 15073 2024-11-25)
Windows 10 (22H2 build ISO 19045.51.31)
Isilon: OneFS version 9.2.1.0
Transfer protocol: S3 using the GUI
See attached log for more informations.
Any suggestions?
Thanks.
Re: Can't connect to Isilon storage with S3 protocol
I do not see any significant difference between the requests sent by WinSCP and by aws. So I cannot tell why the server seems to be closing WinSCP connection. Is there anything useful in server-side logs?
Can you try to connect using IP address in WinSCP, the way you do with aws? (not that I think it helps, but just in case).
lebeg
Hi Martin,
I tried with a new version of OneFS 9.8 and the comunication is working, so the problem is on version 9.2 which probably has a problem with the S3 protocol implementation.
Thanks.
